what year did DEF start in Ford?
2009 E-350 super duty 6.0L. NO DEF??
This engine, the 2009 6.0L diesel, has no DEF fluid tank or Regeneration systems?? I haven’t purchased an owners manual yet but I have driven this truck locally a few hundred miles. 10,20, 30 miles a day.
I’ve worked as a truck driver in trucks that require manual regeneration: parking , flipping a switch and waiting. And I’ve driven trucks that do that automatically while I drive. (Larger delivery trucks.)
This is my first Diesel engine that doesn’t require DEF fluids. So what happens in this engine as far as the PM from the diesel exhaust?
The fact that you don't see it leads me to believe that it has been deleted and reprogrammed. Check under the truck and see if the DPF is missing.
For 2011 and up, def is used and you would fill it at the same location as fuel. When you open the door on the models 2011 and up, you will see two filler spouts. A small one is blue indicating the def. The other is green and of course large for fuel.
All diesel engines built after 2007 are equipped with DPF technology. The last Fords without were the 2007 6.0L. The 7.3L had no EPA restrictions. However the 2003 model year was split with 7.3L in the first half of the run and real junky 6.0L in the last half of the year.
2009 6.0L Super Duty
I really appreciate answers from the community. That’s what makes forums great.
My truck is a E-350 Super Duty chassis that was fitted out as a Paratransit vehicle with seats and a wheelchair lift for patient transport. All the stickers under the hood say 6.0L
We bought it used and are making it into a sort of camper/ mobile home. I was curious why this big 6.0L Diesel took no DEF fluid. I also drove a Sprinter that took the DEF fluid but did the rest automatically. Seeing this engine without any DEF tanks was a first. Thanks again for the answers!!
For model year 2009, it would be a 6.4 diesel motor. For model years 2008-2010 there was the DPF only. It does require the regen you are familiar with. For all the model years, the system worked automatically. You would only see a brief message of "cleaning exhaust filter".
