78 F100 Cleveland 351 Timing Chain
Old 10-14-2017, 02:55 AM
BGF100's Avatar
BGF100
BGF100 is offline
Hi,
I have been chasing my tail with a problem I have been having.
When I start my truck, it idles fast for a few minutes then settles down.
When I park up I get preignition when I switch off.
When I get back to the truck and start it. It tries to idle at low rpm for some reason. (some times it cuts out its at such low revs).
I have been told that it may be the timing chain.
Any thoughts on this. As I dont want to change the timing chain to find it is not the timing chain at fault.
Thanks,
Old 10-14-2017, 05:03 AM
gatorfor88's Avatar
gatorfor88
gatorfor88 is offline
It is probably not the timing chain. Sounds like a fuel issue.
Old 10-14-2017, 05:09 AM
BGF100's Avatar
BGF100
BGF100 is offline
Hi, on the fuel side I changed the carburetor to a new one and the issues still continued.
So, that would only leave the fuel pump right. The original mechanical type.
Could the fuel pump cause this kind of issue?
Old 10-14-2017, 10:40 AM
67xr7kat's Avatar
67xr7kat
67xr7kat is offline
I would suggest getting back to basics before condemning and changing parts. Did you check the ignition timing ? Did you check the distributor vacuum advance ? Did you check the distributor plate for free movement & not stuck or binding from rust ? Did you check the idle stop solenoid to make sure that it isn't touching the throttle tab when the key is off ?
Old 12-16-2017, 11:51 PM
BGF100's Avatar
BGF100
BGF100 is offline
Hi, in gettingback to this. Thinking about it the other way around.
When I have used the truck and park up and come to startup again.
Apart from having to keep the revs up for a while to get the engine to continue to run and not cut out.
It is then closer to 700 rpm. As to when it is started first thing where the revs are 1400 rpm +. I dont have the choke wired up? But may be this is causing high revs. I'm in Australia for my sins.
However, it is summer and is rarely below 15 deg C.
Thanks,
Old 12-17-2017, 12:29 AM
46Whizzer's Avatar
46Whizzer
46Whizzer is offline
Am I correct in assuming you have an electric choke?
If you don't have it wired up it will never fully open, which will keep it in fast idle, and make it more likely to diesel after you shut it off. That would also make it idle poorly once it's warmed up because the engine would be trying to flood out...
Old 12-17-2017, 01:54 PM
BGF100's Avatar
BGF100
BGF100 is offline
Hi, I have a SUM-RM08600VS carburetor. However, I did have an older holley with a mechanical choke and I had the same issues. Thanks,
Old 12-17-2017, 02:33 PM
FMJ.'s Avatar
FMJ.
FMJ. is offline
There was a good suggestion in post 4, but you've completely ignored it !
Australia produces Two Wheel Gods, Bayliss, Stoner, Corser, Dooyan, so I think your sins must be minimal !
Old 12-17-2017, 03:26 PM
72GTS's Avatar
72GTS
72GTS is offline
Air fuel spark. One or 2 of these is off. Check everything related to the spark & fuel. Something is wrong there. Might be a combination of both.
Old 12-17-2017, 04:31 PM
BGF100's Avatar
BGF100
BGF100 is offline
No, did'nt ignore anything. Infact a neighbour and I went over the points made again the other day.
Old 12-17-2017, 04:33 PM
BGF100's Avatar
BGF100
BGF100 is offline
I agree, finding what, is proving to be a pain. However, I know its easy to throw money at these things to find that it was something else entirely. Thanks,
Old 12-18-2017, 12:35 AM
FMJ.'s Avatar
FMJ.
FMJ. is offline
We won't know that you've checked the ignition timing and dizzy unless you say so.
What is the timing set at ?
Is the truck an auto ?
The behaviour of the engine is changing between when it's hot and cold at idle, but what's it like when driving around ?
Check the plug conditions.
Check the HT leads.
Check the coil.
Are there any vacuums leaks ?
Do a vacuum reading at idle. (Is the needle steady and at what level?)
Are the fuel lines away from heat sources ?
Yes, it may be that the timing chain is too loose and screwing up your timing. Can you hear a clattering as if there's something loose ?
Old 12-18-2017, 03:08 AM
boingk's Avatar
boingk
boingk is offline
My bet is intermittent vacuum leak - when warm its not as bad, and the idle is adjusted so the engine starts decently when cold. It'd explain the hot run-on, too, as the lean mix would be causing high plug temps.
Try finding a vacuum leak with WD40 or degreaser when the engine is running.
- boingk
Old 01-20-2018, 10:14 PM
BGF100's Avatar
BGF100
BGF100 is offline
78 F100 celeveland timing chain
Hi, the heat gave up a little today and it remained overcast.
So I took a quick look at the truck.
Took the distributor cap off.
Turned the crank shaft with a breaker bar.
The slop was about 5 - 10mm angular movement at the end of the breaker bar.
Breaker bar approx 12" long. Before the rotor arm began to trun in iether direction.
I have nothing to compare to. Any one with experience care to confirm answer?
Thanks,
Old 01-21-2018, 07:58 AM
palmrose2's Avatar
palmrose2
palmrose2 is offline
Less than 1/2 inch of slop at the end of a 12" bar is no big deal.
BGF100
03-01-2024 02:38 PM
Rusty_Old_F250
04-18-2010 06:52 PM
jrome
12-30-2009 07:17 PM
armoredcar
1978 - 1996 Big Bronco
07-26-2007 12:13 PM
Quick Reply: 78 F100 Cleveland 351 Timing Chain
