Fluid for 3 speed toploader
Old Oct 13, 2017 | 01:03 PM
cris.phoenix87's Avatar
cris.phoenix87
Good afternoon gents, does anyone know the best fluid to use on a 3 speed top loader transmission. I’ve got a few different responses from various people in the neighborhood but wanted others opinions from the ford forum. Thanks Chris
Old Oct 13, 2017 | 09:17 PM
1972RedNeck's Avatar
1972RedNeck
Petroleum based oil betwixt the viscosity of 30 weight and 50 weight - temperature depending of course.
Old Oct 14, 2017 | 11:43 AM
rexblue's Avatar
rexblue
The shop that rebuilt my Borg Warner 3od recommended ATF. (!!!) I thought the man was pullin' my leg at first.
rx
Old Oct 15, 2017 | 04:20 PM
SuperSabre's Avatar
SuperSabre
Weren't you going to call me?
Old Oct 15, 2017 | 04:28 PM
Tedster9's Avatar
Tedster9
Can't go wrong reading the shop manual or operator's for correct fluids and capacities. Ford specified straight 50 wt mineral oil, at least in 1964
Old Oct 15, 2017 | 05:08 PM
KULTULZ's Avatar
KULTULZ
Question
ATF??? ...
-Gear Oil - 80W-90-
Gear Oil
Brad Penn multipurpose Classic GL-4 gear oil is specially blended using high-quality Penn Grade mineral base stocks and select additive technologies. It is designed to be used with yellow metallurgy (brass, bronze, copper) and other soft metals used in synchronizers, bushings, thrust washers, and other components typically found in classic manual transmissions. In applications that require API GL-4 quality lubricants, use of API GL-5 lubricants with higher extreme pressure additive concentration can damage these soft metal components.
Any quality brand 80W-90
I haven't seen 50W used since the seventies and that was in a 10S ROAD-RANGER.
Old Oct 15, 2017 | 06:29 PM
1972RedNeck
I use 80w-90 in all of my manual transmissions. Whenever I post that on here though, I get somebody that tries to inform me that these transmission were designed to use 30 to 50 weight oil and that 80W-90 results in impossible shifting, catastrophic failure, death, etc.
Personally I would fill it with 80W-90 GL5 and never look back. Heavier oil tends to make it shift better and it helps keep gear noise down.
Old Oct 15, 2017 | 07:44 PM
KULTULZ's Avatar
KULTULZ
Post
Well. I'll tell 'ya...
Lubes have changed so much since then that you have you use a LUBRICATION CHART, especially on EUROPEAN and ASIAN.
Rule of thumb was ATF in most anything with an aluminum case but you have to have the proper service literature or your paycheck may be lacking come Fri. afternoon (no Happy Hour)
Old Oct 15, 2017 | 10:04 PM
Tedster9's Avatar
Tedster9
I've used 80/90 gear oil for 20 years. Supposedly the modern stuff trashes yellow metals (brass) synchros. If it does, it must take a while. But the manual calls for 50 wt, jus sayin'.
I expect the viscosity is similar to gear oil, I don't believe gear oil and motor oil is measured the same way or some such.
Old Oct 16, 2017 | 07:12 AM
matthewq4b's Avatar
matthewq4b
Originally Posted by KULTULZ
ATF??? ...
-Gear Oil - 80W-90-
50W is readily available you can even get it at Walmart.
https://www.walmart.com/ip/Synthetic...d-50W/38691721
Several newer heavy duty transmissions are using it.
Old Oct 16, 2017 | 07:43 AM
hiball3985's Avatar
hiball3985
Correct, gear oil and motor oil viscosity isn't measured the same way. 50W motor oil is about the same viscosity as 80-90 gear oil. I've been running 80-90 in all my trans since back in the 70's. I only use GL4, GL5 additives will destroy your brass synchros..
Old Oct 16, 2017 | 08:27 AM
KULTULZ's Avatar
KULTULZ
Question
What manual?
Old Oct 16, 2017 | 08:31 AM
KULTULZ's Avatar
KULTULZ
Question
...ok...
Old Oct 16, 2017 | 12:17 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally, it was 90 weight gear lube.
Old Oct 16, 2017 | 12:28 PM
Tedster9's Avatar
Tedster9
What manual?
How many manuals do you think there are, Gus?
The Ford Truck Shop Manual
Pg 21-1 SAE 50 above 10° SAE 30 below 10°
Alternate listing is 90 wt gear oil (No EP additives) above 10° 80 wt gear oil below 10°
