Bad coil?
Old Oct 11, 2017 | 05:04 PM
Joe777's Avatar
Joe777
Bad coil?
The "Ign" post on my 6v coil is loose. I can turn it about 1/8 turn back and forth. Does this mean the coil is bad? The motor recently started to exhibit signs similar to vapor lock and I'm wondering if this coil could be the culprit. Thoughts?
Old Oct 11, 2017 | 08:36 PM
willowbilly3's Avatar
willowbilly3
Try a know good unit. There are primary and secondary resistance values but they won't always show an intermittent problem.
Old Oct 22, 2017 | 05:49 PM
Joe777's Avatar
Joe777
I think I got to the root of the problem. We had the carb and fuel pump rebuilt and I installed a good coil. Truck ran real nice - for about 15 minutes and then it started running badly again. After we got it home we disconnected the fuel line at the tank valve to check for flow.
Nothing. Zip. Not a trickle. We blew some air thru the valve and the fuel ran as normal.
Any suggestions on how to thoroughly clean the fuel tank?
Old Oct 22, 2017 | 08:05 PM
bernette's Avatar
bernette
i steamed clean mine and , put a chain Inside and shook it as best i could . done that for a few hours,until nothing came out. then i sent it to a old guy who had some red stuff to cover the Inside. the name of the product i,m unsure but the empty can is at the shop. suppose to seal pin holes and seal up all the loose rust scabs.i did use it afterwards but not much. its sitting empty in my garage.
Old Oct 23, 2017 | 06:36 AM
Joe777's Avatar
Joe777
Steam cleaning and a chain sounds like it should work. Not sure yet if I want to coat the inside. I found something called Red-Kote that looks effective. Seems like it would be hard to ensure all surfaces inside are covered and all excess coating is drained.
Old Oct 23, 2017 | 10:54 AM
newold46's Avatar
newold46
I took mine to get tanked and sealed at a radiator shop.
Old Oct 23, 2017 | 06:12 PM
bernette's Avatar
bernette
joe i belive its red-kote . i know for sure the product was red.
flipklos
May 10, 2011 10:07 PM
cliffordingles
13
Mar 8, 2011 10:38 AM
6CylBill
Escape & Escape Hybrid
Dec 14, 2008 09:13 PM
Freightrain
Apr 19, 2004 06:24 PM
8996EBBroncos
1978 - 1996 Big Bronco
15
Jul 1, 2003 12:35 PM
