turn signal problems
Old Feb 10, 2005 | 09:40 PM
the peppermint's Avatar
the peppermint
every time i try to do a search it is always to busy, so i will ask a new question, has anybody had a problem that when you turn on the blinker both rear lights blink, tail lights do not work and brake lights don't work when head lights are on. if anybody has a clue as to what this might be, please clue me in
Old Feb 10, 2005 | 11:23 PM
mstarr's Avatar
mstarr
Is this a new problem, when did it start? Sounds like a short or someone did a bad job of installing a trailer light wiring harness. Or could have the wrong bulbs installed, but that is a long shot.
Old Feb 11, 2005 | 02:40 PM
ronclark's Avatar
ronclark
check the bulbs in the rear and make sure you used the proper bulb. If you put a single terminal bulb where a double terminal bulb goes, it will short your turn signal and brake lights together. That will cause both bulbs to blink because both brake lights are on the same wire and with the turn signals shorted to the brake lights, then turning on the turn signal uses the brake light wires to power both bulbs. Same problem with the brakes with the head light on. The tail lights are shorted to the brake lights and the brake lights don't come on because they are already on with the tail lights.
Old Feb 11, 2005 | 11:04 PM
the peppermint
turns out i had a bad ground (too much playing in the mud)
howaboutthisone
Escape & Escape Hybrid
18
Jun 28, 2010 12:11 PM
apbtpetey
Electrical Systems/Wiring
Dec 1, 2008 02:18 PM
jrg24
1983 - 2012 Ranger & B-Series
Nov 5, 2008 12:12 AM
paintballakevo
Dec 31, 2003 10:17 PM
NitrousAl
1978 - 1996 Big Bronco
Nov 26, 2001 09:06 PM
