Programmer causing high idle?
2001 F250 7.3
Long story short-
I took my truck to my local diesel shop to solve a draining batteries issue that had been haunting me. They determined it was the GEM, so they replaced it and re-flashed it.
Battery drain issue is still there, but now it also won't come out of high idle.
I have a programmer on it, but have no idea which one it is because it was there when I bought it.
The **** on the dash has 4 positions, and position 1 is high idle. Position 4 is more power (enough to blow smoke). Position 3 is also more power, but not as much as 4. Position 2 may be more power or it may be stock. I don't know. I usually keep it on 3.
Anyway...the **** does nothing now when I turn it. I traced the wires back as far as I could last night, but got lost up there and found nothing.
It doesn't seem to plug into the bottom of the PCM like the TS 6-Position chip unless they hid the wires REALLY well.
1. Does this programmer sound familiar to anyone?
2. Is this causing my high idle?
3. How can I fix it?
I got tired of being without the truck, so I have it back from the shop now (after 4 months of them trying to figure things out) and am driving it with the high idle.
Thanks
Can’t really help, but this thread deals with high idle issues if that helps
https://www.ford-trucks.com/forums/1...001-7-3-a.html
