High Idle?
Old Dec 11, 2006 | 10:42 AM
sandlapper's Avatar
sandlapper
High Idle?
In the 7.3 are there wires we can tap into for the high idle? If so, where might they be and are there two different wires like in the 6.0. I think there is a Battery charge protected and another one. I can't remember what it is called.
I'm interested in the BCP wire.
Thanks in advance.
Old Dec 11, 2006 | 03:13 PM
ryaneverk2's Avatar
ryaneverk2
Here's a recent thread with info on constructing a homemade high idle setup:
https://www.ford-trucks.com/forums/5...highlight=idle
The 7.3 doesn't have built-in wires like the 6.0 does for high idle, unfortunately. Have to rig up our own setup to duplicate it.
You could also get a Ford APCM unit that will give you high idle, or have someone like DP-tuner burn a high idle program for you.
