Bed wheight question
Old Oct 9, 2017 | 07:00 AM
orion1968's Avatar
orion1968
So I have been reading a lot of info on the F250 and why it is maxed at 10k (registration fees etc) even though it is 1 leaf shy of the F350. My sticker says somewhere around 2050lbs cargo. How can it be so low compared to the 350? I also see a lot of people adding the air bags. Does this "legally" increase the capacity?
Reason I ask is the 5th wheels I am interested in have ~2100 pin weight loaded. I know the 6.7l wont have a problem pulling it. I have the 5th wheel/goose neck, snow plow (didn't need this but every truck on the lot had it), and ultimate tow packages.
Old Oct 9, 2017 | 07:04 AM
tibadoe's Avatar
tibadoe
Originally Posted by orion1968
........I also see a lot of people adding the air bags. Does this "legally" increase the capacity?.........
No. The weights listed on the door jam sticker are the "legal" weights.
Old Oct 9, 2017 | 07:08 AM
cattaco's Avatar
cattaco
How much does the powerstroke weigh over the 6.2? I'm surprised your payload is that low. My ccsb 4x4 lariat with the 6.2 has 3150lbs payload.
Old Oct 9, 2017 | 07:37 AM
A&Pmech's Avatar
A&Pmech
The powerstroke adds around 800lbs. If you think the f250 is bad go check out a mega cab 2500 ram with the Cummins, it's payload is down around the 1600-1700 range.
The reason the payload is so much lower than the 350 is because the gvwr is 10k and the weight of the truck itself takes up 8k of that.
Slowandsteady
Dec 31, 2017 09:04 AM
noimports
Feb 6, 2017 01:38 PM
castelle
Dec 8, 2016 11:58 AM
JandC
6.7L Power Stroke Diesel
73
Dec 12, 2014 08:38 AM
flyMike
Jan 11, 2008 11:41 PM
