Predict my payload?
Old Feb 5, 2017 | 11:36 PM
noimports's Avatar
noimports
Predict my payload?
Anyone care to guess what my payload will be? Or maybe you already have my truck with similar equipment. I ordered an F350 CC LB SRW, 6.7, 3.55 with 20 inch wheels, Lariat Value Pkg, nav, chrome, 5th wheel prep, tailgate step, spray in liner, FX4, no sunroof. I'm gonna guess 33-3400. But you won't hurt my feelings if you say more.
Old Feb 6, 2017 | 01:03 AM
KYLongRifle's Avatar
KYLongRifle
My fully loaded F-350 PlatU 6.7 CCSB SRW Snow plow prep and 5th wheel prep got 3277lbs. The long bed will give you probably +100lbs over mine (theoretically axles can handle the same), and i would guess that less the sunroof would get you close to another +100lbs.
My guess: 3497lbs!
Old Feb 6, 2017 | 01:32 AM
noimports's Avatar
noimports
My guess: 3497lbs!
I would be very happy if you were right but correct me if I'm wrong, wouldn't a long bed weigh more, resulting in a lower payload?
Old Feb 6, 2017 | 01:51 AM
KYLongRifle
Your exactly right about it weighing more.... But what has to be taken into account is that payload seems to be calculated by Ford as an equally distributed weight over a given area. Therefore the larger area in the LB can handle more weight. This was the only logical conclusion i could come up with when looking at the numbers on the Ford fleet towing guides. Same axle and setup, long beds always ended up with a higher payload "rating" <--- theoretically. For me i was only worried about my heavy pin weight of my 5vr, so i choose SB since i know it is less weight onto the drive axles. Weight police may freak out with me saying that, but I trust the axle rating way more than the payload calc's.
Old Feb 6, 2017 | 03:51 AM
mikerosane's Avatar
mikerosane
I have essentially the same truck. My payload is just under 3400#
Old Feb 6, 2017 | 06:19 AM
noimports's Avatar
noimports
Thanks mikerosane. So does anyone know if that is with a full tank of fuel? And does it assume an empty cab or allow for a driver? This is my third SD and I've heard both ways. I'm trading in a dually so I never really cared before.
Old Feb 6, 2017 | 10:09 AM
gspv's Avatar
gspv
Your unloaded vehicle weight includes a full tank of fuel, full oil, full radiator, etc.
I have seen definitions that include like 155 lbs for the driver. Not many of us weigh that little.
Passengers, tool box, fifth wheel hitch, etc, all come out of your payload.
FWIW, Ive been told that the AT tires vs the AS tires have a higher weight rating and help payload.
Old Feb 6, 2017 | 01:02 PM
noimports's Avatar
noimports
Yeah I really wish Ford would up the GVWR on the SRW to 12,000. Ram is at 12300 with the Aisin trans. But that's my only complaint so far. Love all the new improvements including the 48 gallon fuel tank.
Old Feb 6, 2017 | 01:30 PM
ELJ1st500's Avatar
ELJ1st500
Payload
Hello,
Your truck and my truck are equipped nearly the same. I do not have nav or chrome on mine. Payload is 3,159. I was hoping for a little more too, but it is what it is.
Thanks,
Eric
Old Feb 6, 2017 | 01:38 PM
crewzer's Avatar
crewzer
Lightbulb
Ford's 2017 Sd Orger Guide Supplement says the max GVWR for your configuration is 3,680 lbs. I presume this is for the XL trim with no/few options, so you'll need to take a whack at guestimating the weight of your various options.
HTH,
Jim / crewzer
KC8QVO
Dec 8, 2020 02:56 PM
castelle
Dec 8, 2016 11:58 AM
JandC
6.7L Power Stroke Diesel
73
Dec 12, 2014 08:38 AM
Paratrooper84
47
Aug 14, 2012 08:39 AM
JJinEdgewood
All Things Towing
May 31, 2004 12:02 AM
