Clear Cab Lights?
Old Oct 8, 2017 | 06:44 PM
Glaxtx's Avatar
Glaxtx
Clear Cab Lights?
I've been looking online and Amazon trying to find clear cab lights for my 2017. They all show to fit but when asking sellers they say they only fit to 2016. I'm looking to replace the stock covers to clear with amber bulbs without getting an entire kit that requires rewiring. Anybody have advice on where to look?
Old Oct 8, 2017 | 07:45 PM
MrFord619's Avatar
MrFord619
Seeing that the 2017 lights don't exactly contour too well with the roof line, I'm sure plenty of lights of similar dimensions would fit just fine.
Old Oct 8, 2017 | 07:55 PM
reseehc_99's Avatar
reseehc_99
You can not just remove the housing on the clearance lights on the '17. You have to replace the whole light. Recon has a kit, but I'm not sure how much it is to swap over.
Old Oct 9, 2017 | 01:26 PM
f350ktm's Avatar
f350ktm
Here is a thread I posted some time ago that may have some information that will be of help.
2017 Clearance Light Removal
Good luck and let us know how it goes.
Old Oct 9, 2017 | 01:51 PM
bushpilot's Avatar
bushpilot
its not a simple (colored) lens replacement - the '17s cab / clearance lights are one piece, and as such the replacement is of the entire (molded) assembly, lens, base and all.
removal of the lights requires removal of a (stubborn) foam gasket (on job 2+) truck and the recon replacement kits may contain new gaskets.
earlier produced '17s may not have the gasket and could be a source of leaks, some have successfully applied silicon/form-a-gasket upon reinstallation of the OE or Aftermarket lights.
Old Oct 9, 2017 | 06:20 PM
Glaxtx's Avatar
Glaxtx
Thanks for all the help. Great write-up ktm, that is very helpful as I was concerned about removing the entire assembly before. Those look great on your truck!
FordOwnerJoey
Jan 21, 2014 08:35 PM
linckeil
31
Dec 31, 2012 05:47 AM
KevinC.
15
Jul 16, 2010 04:07 PM
danorules
2004 - 2008 F150
Jun 30, 2010 08:59 PM
jeffdoerr
Jul 27, 2006 08:29 AM
