OK, I can't find one under the hood. I looked and found the little data connector under the steering wheel. It will not fit my code reader. The old system used two connectors. One was an odd shaped connector. The other had only one wire. The new one is a simple rectangular connector.
So I guess they changed the system between 94 and 96. Is that correct?
