Why does Ford have a solid front axle?
Old Oct 6, 2017 | 04:35 PM
RedRage's Avatar
RedRage
My neighbor brought over his new GMC 3500 to compare trucks with my 2017 F350. He likes the IFS for its car like ride and he says Ford should ditch the old school SFA. I listened to him for a while and then it was time to go. He pulls into the street and shows off by putting his truck in 4x4 and spinning all 4 tires and thats when it happened. BLAMO! The front IFS let go with a crack and a pop and that was the end of it. He does have slightly bigger tires on it but was still not a good showing for his GMC. I did not rub it in but I think he understands the difference between a Dana Super 60 and his IFS.
Old Oct 6, 2017 | 04:40 PM
Mud Doc's Avatar
Mud Doc
Well, that is really good use of any truck...I would think to get all 4 spinning, he had to really hold on the brake?
Any permanent damage?
Old Oct 6, 2017 | 04:43 PM
RedRage's Avatar
RedRage
Damage
There was damage. He dropped one end of a half shaft and there was an oil leak. He had it towed to the dealer.
Old Oct 6, 2017 | 05:03 PM
Large's Avatar
Large
Upper and lower control arms don’t belong on a 3/4 - 1 ton pickup. Just my 2 cents.
Old Oct 6, 2017 | 05:08 PM
69cj's Avatar
69cj
Did you tell him he answered his own question? You could also clue him in that a 4X4 was not designed for 4 wheel burn outs on asphalt.
Old Oct 6, 2017 | 05:16 PM
cattaco's Avatar
cattaco
How could he have possibly spun all 4? The GM ifs is actually pretty strong anymore, but I still hate it.
Old Oct 6, 2017 | 05:34 PM
Tarster's Avatar
Tarster
Rides like a car, breaks like a car.. Solid front axle for the weight capacity and strength, plus aftermarket parts are plentiful.
Old Oct 6, 2017 | 05:44 PM
DSLTRK60's Avatar
DSLTRK60
The main benefits of a solid axle are less wear points. Ball joints on independent suspension cycle frequently while ball joints on the solid axle knuckle cycle only when turning.
Old Oct 6, 2017 | 06:32 PM
82_F100_300Six's Avatar
82_F100_300Six
Bring back the twin traction beam
Old Oct 6, 2017 | 06:55 PM
j759ll's Avatar
j759ll
this has nothing to do with the manufacturer this is an idiot destroying his truck to show off nothing more.
Old Oct 6, 2017 | 07:13 PM
A&Pmech's Avatar
A&Pmech
Sounds like something a 16 year old kid would do. I'm a GM guy and have owned plenty of them, I can't tell a difference in ride quality with my f250 solid axle and the 7 or 8 GM trucks I've had.
Old Oct 6, 2017 | 07:15 PM
KCJackson1's Avatar
KCJackson1
Independent front suspensions can be plenty strong... ask anyone in the military who has driven HMMWVs and 6x6s. Ford and Ram use SFA on their heavy-duty 4x4s for two reasons - cost and customer request. It's a less expensive front end to develop/maintain, and people still want it. Ford could put a very rugged IFS under the F-450 if they wanted, but customers probably wouldn't like the price.
Old Oct 6, 2017 | 07:22 PM
Sir Kayakalot's Avatar
Sir Kayakalot
WHAAAAAT?!??!?! Something so spectacular and you didn't get any pics???? Come on....what a missed opportunity!
Old Oct 6, 2017 | 09:11 PM
RedRage's Avatar
RedRage
Then put IRS in the rear.
Anything can be made strong, even ifs. But GM does not build them that way. IFS has an inherent weakness that a solid axle just does not have. Thats just the way it is. If there that good then GM should put independent suspension in the rear too. Only a solid axle in the rear would work.
Old Oct 6, 2017 | 09:30 PM
DSLTRK60's Avatar
DSLTRK60
I don't think the current GM IFS is weak by any means, just more costly to maintain. Ford and RAM continue the solid axle trend because it's cheap to build, easier to align, and customers continue to want them.
You won't see independent rear suspension, because it would be far too costly to engineer/build a system to handle the weight requirements of today's HD pickups.
The military can afford 5 ton trucks with independent rear suspension, but again those probably cost $500000 each.
