Fuel pump issues
Old Oct 6, 2017 | 12:15 PM
Ionlydrivefords's Avatar
Ionlydrivefords
Fuel pump issues
I have a 1989 Ford F250 4x4 with a 5.8 in it.
I replaced the tanks and pumps with tanks and pumps out of a 1990 f250,
for the 1990 fords im aware that the fuel pumps had components in one unit, So I removed the components of the frame, and I rerouted the fuel lines but now I got gas coming out right from the rear tank.. but its weak but the front pump was working but now it dosent pump gas to the engine it pumps it to the rear tank which is empty. should I bypass the rear tank? or put the old pump back on the frame?
I need help asap
Old Oct 6, 2017 | 12:43 PM
94ZR580's Avatar
94ZR580
I think that your 89 had a high pressure pump on the frame and low pressure pumps in each tank. That is the way my 88 is. If the 90 in tank pumps are not high pressure pumps, then you would need the pump and distribution block stuff from the original set up to make things work and get the return lines delivering fuel to the correct places.
Old Oct 6, 2017 | 12:56 PM
rla2005's Avatar
rla2005
The rear tank probably has a bad check valve in the fuel delivery module. A very common problem on the 1990 and later F-series gas engine trucks with dual tanks.
The bad valve allows fuel from the front pump to fill the rear tank.
Old Oct 6, 2017 | 03:06 PM
Ionlydrivefords
Okay good to know, I completely disconnected the rear tank, the truck starts now.
And I put the high pressure pump back on.
Old Oct 6, 2017 | 03:26 PM
rla2005's Avatar
rla2005
The 1990 and later F-series gas engines trucks have a high pressure pump in each tank. Your setting yourself up for failure by installing the 1989 inline high pressure pump. Completely redundant and unnecessary.
Old Oct 7, 2017 | 02:28 PM
Ionlydrivefords
okay I removed that, my regulator was dead I think because I had pressure in the fuel lines right up to the regulator but.. no fuel in the fuel rail, I replaced it with a newer one.
Hopefully I can get the truck started.
I need to sell it since I got no money left lol
Old Oct 8, 2017 | 08:01 AM
subford's Avatar
subford
The regulator is after the fuel rail, not before it.
Old Oct 8, 2017 | 11:12 AM
Ionlydrivefords
right, I put a new pump in, still no fuel going to the fuel rail.
gonna take it off and clean it out today
jskeith47
Jul 11, 2015 11:01 AM
oldford65
Apr 13, 2013 03:33 PM
LADNAR
Feb 24, 2011 09:24 AM
Duceswild
Nov 3, 2007 06:23 AM
LumberJact
Nov 19, 2005 09:40 AM
