93 F-150 shifter problem
My shifter is sloppy,. I can wiggle it all around. I don't know where the problem is. I think its somthing up top on the steering column. But I dont know how to even access it to check it. I don't think anything is bent underneath. I was. Having a problem before trying to shift it in park
Probably shifter tube broke or bushings just plain wore out,easy fix
1.pull covers off column 3 phillips from underneath-need to remove ign lock cylinder-use a small punch with key in on position to depress release pin. After covers are off reinstall cylinder so you can switch off ignition while replacing shift tube assy.
2. drop colum-4 nuts hold it up
3.use suitable small pry bar or screwdriver to pop off shift cable from tube assy.
4.bolts holding tube assy to colum are torx remove them and shift interlock bracket. then remove assy take to bench.
5. there are 2 drive pins holding everything together remove them transfer needed parts to new tube and reinstall.
tube assy is available at autozone, napa, advance etc about 30 to 50 bucks.It took longer to type this than to do the job takes.
F250_
12-12-2016 07:50 PM
