Hydroboost problems
Old Oct 6, 2017 | 07:06 AM
Jmiller68's Avatar
Jmiller68
Hydroboost problems
Need some help! I attempted to install hydroboost on my 68 off a 6.0 powerstroke. I don't have assist, and blew fluid out of resivoir. Drove short distance. I checked my high pressure routing, I believe is correct. I checked it with my 7.3 powerstroke and online diagrams for 6.0. I don't know if resivoir is tilted to much with aftermarket bracket, second drain I weld on causing issue, possible bad used booster, air in system, bad pump or can't flip booster over? Any suggestions would be appreciated.
Old Oct 6, 2017 | 09:37 AM
kenny nunez's Avatar
kenny nunez
Hydroboost
The booster can be mounted in any position. It looks like the pump needs to be in a more vertical position. I have Hydroboost on my 67 Ford passenger car, I plumbed the fluid exhaust hose into the return line to the pump. Since fluid continues to run through the booster until the brake is pressed it is probably just blowing too hard into the bottom of the pump.
Old Oct 12, 2017 | 01:03 PM
Jmiller68's Avatar
Jmiller68
Update, problem was bad saginaw pump. I installed a petcock valve on return, notice right away fluid flow was low or restricted. Replaced pump and now works great. So those that want to turn booster upside down, it does work.
Old Oct 12, 2017 | 02:56 PM
TeachNlive4ever's Avatar
TeachNlive4ever
Thank for being the guinie pig
F-250 WARHORSE
Feb 19, 2018 09:12 PM
verce12
Nov 27, 2009 11:36 PM
carlsson
Dec 22, 2008 08:43 PM
dagren99
18
May 2, 2007 11:02 PM
