302 Tranmission
That transmission is 100% electronic controlled, any faulty sensor can trigger limp mode. More details why you state "one foot in the grave"?
Based on your profile your 1994 F150 will most likely have a 4R70W transmission. That was most common for your model/engine for that model year.
It is also electronic controlled.
If you haven't done so get some gauges for a line pressure test. The test procedure is relatively simple, you need to establish if the transmission is pushing the right amount of fluid around, given that you stated there are no codes stored in the memory. After that, drain the fluid from the pan through a white cloth and check for metal debris/clutch material.
Eddiec1564
11-09-2007 06:26 AM
purevilife
05-22-2005 03:30 PM
Sand Bronco
06-21-2004 11:59 PM
