Headlights quit
Old 10-04-2017, 09:32 PM
hotrodfeguy's Avatar
hotrodfeguy
hotrodfeguy is offline
Headlights quit
Both my HL quit working. I would guess bulb but both went at the same time. As well as having running lights. What/where should I look for first?
Old 10-05-2017, 05:18 AM
afmedic's Avatar
afmedic
afmedic is offline
Check fuses, then bulbs (even though they both went at the same time). If fuses and bulbs are good, break out the volt meter and check for 12v at the headlight plugs. If no power, check the switch
Old 10-05-2017, 09:55 AM
BillyBob69's Avatar
BillyBob69
BillyBob69 is offline
On your 99 you not only have the fuse panel under the dash but one at the top back corner under the hood on the drivers side. Check those too.
If you dont have the layout for the fuses let me know and i will scan my owners manual pages for the fuses.
Old 10-07-2017, 07:44 PM
hotrodfeguy
Turns out I bumped the plow switch LOL
Old 10-08-2017, 09:40 AM
BillyBob69's Avatar
BillyBob69
Lol. It happens to the best of us.... right?
At least it was an easy fix!
Old 10-08-2017, 09:37 PM
ExPACamper's Avatar
ExPACamper
ExPACamper is offline
I did that in the '86 Ford in the late 80's. Nice toggle switch, too
Glad you found it!
shnoop
11-20-2016 06:36 PM
1979redf250
05-31-2014 08:58 AM
conoso
08-01-2012 07:49 AM
merlynr
Electrical Systems/Wiring
05-31-2012 01:46 PM
LasWagen
1983 - 2012 Ranger & B-Series
09-27-2006 07:10 PM
Quick Reply: Headlights quit
