Well, I finished up the relay project. Even though I had never done this before, and was a bit intimidated with all the complicated wiring, it was really pretty simple once I got the hang of what makes a relay tick. Last night I cinched everything down and turned the lights on, and....my high beams worked fine, but, no low beams.
I started testing all the connections, and it turned out my ground wire on the LB relay was not making contact. Got that fixed, and took it out last night to see how well things worked. Lights were brighter than ever, and no flickering. I sure appreciate all the replies and help on this project.
