Flickering Headlights 74 Bronco
Old May 27, 2012 | 02:57 PM
HOODRAT's Avatar
HOODRAT
Hey Guys new to FTE any help would be appreciated. Got two trucks with the same problem. After roughly 15 min headlights start flickering on and off? Any solution ideas?
Old May 27, 2012 | 03:01 PM
arctic y block's Avatar
arctic y block
Head light relay over heating do possibly to a bad ground.
Old May 27, 2012 | 05:22 PM
HIO Silver's Avatar
HIO Silver
Power to the headlights goes through the headlight switch and is kicking on (and off) the headlight relay.
One solution is to simply replace the headlight switch... BUT a better solution is to install relays sourcing voltage directly from the battery and use the headlight switch signal to energize the relays.
You can buy or build a harness. LMC has 'em for $30 or here's a wiring diagram:
Old May 27, 2012 | 05:37 PM
arctic y block
Unless the rig is all rusty and some wires are rubbing through to ground. This harness may cure it if the problem is there. But it could be anywhere on the truck. Just saying.
Old May 27, 2012 | 07:41 PM
HIO Silver's Avatar
HIO Silver
Yessiree Arctic.....I am working under the assumption that the OP has done some troubleshooting like checking for damaged wiring.
But if the OP simply posted a question in this here FTE without doing a modicum of homework, then that would simply be super lame.
Old May 28, 2012 | 04:07 PM
HOODRAT's Avatar
HOODRAT
I do like the idea of the relays, think i will do it with both rides. Sounds like a sure bet. replaced dimmer switch and head light switch on bronco when i changed harness, wish it would of been that simple.thanks to you both, i am grateful, check out my rides and let me know what you think, again grasias!
Old May 28, 2012 | 10:19 PM
arctic y block
So did ya fix it?
Old May 29, 2012 | 12:11 AM
jacks61ford's Avatar
jacks61ford
sounds like it needs a ground between the body and battery
Old May 30, 2012 | 06:14 PM
HOODRAT's Avatar
HOODRAT
not yet gotta pick up a few things,got other truck in shop right now,maybe i pull bronco in this weekend.
1968 F250camper
15
Oct 29, 2017 08:21 AM
67' Dually
15
Apr 16, 2014 04:57 PM
karjunkie
Feb 18, 2014 12:25 PM
Myfreeford
Nov 11, 2012 09:14 AM
rankhankyellow
Electrical Systems/Wiring
Feb 23, 2007 06:41 PM
