1994 automatic shifter problem
Old Oct 3, 2017 | 01:30 PM
KennyCoulter's Avatar
KennyCoulter
I am helping a friend work on his truck. Out of nowhere, the gear selector will now move all of the way from P to 1 with just the key turned to "run" position.
Under the vehicle, you can move the trans gear selector separately through seemingly all of the gears, without having a foot on the brake, key in, anything.......
I imagine that something in the COLUMN is broken, and NOT in the transmission itself.
I tried searching first, but didn't find anything. Is this a common problem or an easy fix?
Old Oct 9, 2017 | 09:12 AM
KennyCoulter
I finally got to look at it in the daylight. I do not know if there is a difference between earlier and later Rangers, but this 1994 splash has the cable only going to the firewall and connecting to the column outside the firewall.
The problem was the ball stud on the end of the column shifter is directly below the master cylinder/booster. It got drenched in brake fluid, and of course over time, rusted into almost nothing and the cable end just slides on and off.
I do not know the original size of the ball stud, but we are now cutting the old off and drilling through the bracket and will replace with a new ball stud once we find the correct size. I am currently thinking that it is a 10mm ball...... if anyone knows for sure, that would definitely help out.
Nicklatech
Mar 25, 2019 09:57 AM
hjartland
Feb 22, 2017 03:15 PM
teamlx88
Jan 4, 2015 01:40 PM
IZZYAZ
Aug 18, 2009 08:29 AM
drofman
Oct 15, 2003 11:13 PM
