Headlights only work with ignition off
Old Oct 2, 2017 | 08:51 PM
Skilledcjb's Avatar
Skilledcjb
So thanks in advance, cant find a solution to this, headlights not working while truck is running, no high or lows or flash, but if I shut the truck off headlights work fine highs and lows, all fuses checked and fine. Also all other lights and electrical working fine. Please help 2000 f350 7.3l cm sk2 flatbed srw 4x4 6.5" procomp lift hdx front bumper
Old Oct 3, 2017 | 11:58 AM
Colorado350's Avatar
Colorado350
I would pull out the Multimeter and see what is going on with your voltage when you're actually turning the key. Check fuses/relays for a bad i.e. Melted, slight crack etc.
Old Oct 3, 2017 | 05:29 PM
DieselDenny's Avatar
DieselDenny
Plow on it???
Old May 29, 2018 | 08:36 PM
Brandon Crile's Avatar
Brandon Crile
Originally Posted by DieselDenny
Plow on it???
I have a plow attachment and cleaned out my truck the other day and this started to happen. Any ideas?
Old May 29, 2018 | 09:02 PM
Walleye Hunter's Avatar
Walleye Hunter
There is a switch that switches your headlights from normal headlights to the plow lights. When the switch is flipped the regular headlights won't come on and the plow lights light. I'm going to guess that you bumped that switched and that its power is keyed so it only functions when the key is in the on position. Find that switch and change its position and see if it doesn't solve the problem.
Old May 29, 2018 | 11:09 PM
Bonanza35's Avatar
Bonanza35
Like to know what you find. Interesting,
Giuseppe1425
15
Jul 29, 2024 03:43 PM
brian42
Mar 6, 2018 06:46 PM
western star
May 26, 2013 10:12 AM
burntice
May 20, 2012 06:20 PM
phillijp
Nov 22, 2003 10:15 PM
