Fuel injector
Old Sep 30, 2017 | 07:22 PM
tcjhkbjt's Avatar
tcjhkbjt
Fuel injector
Is there anyway to check the fuel injectors without removing the valve covers
Old Sep 30, 2017 | 07:58 PM
TooManyToys.'s Avatar
TooManyToys.
What are you trying to check them for?
Performance wise, you can only properly check them with an IDS while in the vehicle.
Old Oct 1, 2017 | 12:23 PM
tcjhkbjt's Avatar
tcjhkbjt
Truck running real rough and I have a code cylinder 2 injector circuit. Wondering if I have a bad injector.
Old Oct 1, 2017 | 12:59 PM
catapeed's Avatar
catapeed
You can do a buzz test if you have the software otherwise you can unplug the connector and see if the engine sound changes if not that you most likely have a failed injector.
Old Oct 1, 2017 | 01:31 PM
xcrsp440's Avatar
xcrsp440
If you have the equipment run a relative compression test to confirm the cylinder is healthy. If it is good you probably need a new injector.
Mike Bartlett
Jul 26, 2019 03:15 PM
rusbukt
Sep 22, 2014 07:56 PM
smitty403
Mar 10, 2014 03:24 PM
UNTAMND
May 6, 2010 09:13 PM
swirk
Dec 7, 2002 09:15 PM
