I have an 04 f250. Someone tried to steal it the other day but was unsuccessful. Although they did break my ignition cylinder. Question is when replacing it I need to know if my truck has the transponder in the key or not so I can get the right cylinder. Thanks.
As long as he doesn't have a Harley Davidson, he won't have PATS. Good post, reps sent brother!
OP use White Bear Lake Ford Parts(Put that into google) and use that website to order from. 99% of the time it will be cheaper from anywhere else, the only other place that can 1/10th of the time match or get close is Ed from FICMrepair. Both are site sponsors, let us know how you come out.
