Sponsored by: Real Truck
Key in the ignition ringing, please stop!
Old Jul 28, 2006 | 08:10 AM
hdrider876's Avatar
hdrider876
Cool Key in the ignition ringing, please stop!
I have an '04 SD PSD and I like to leave the doors open after I wash the truck to listen to the stereo while drying it off. The ringing from the key being in the ignition drives me crazy. Can anyone tell me how to disconnect this without affecting anything else.
Old Jul 28, 2006 | 10:11 AM
DirtyDieselPhil's Avatar
DirtyDieselPhil
This mod has been posted many times, but here ya go:
Turn ignition to RUN
(do not start), insert prodding tool in hole under ignition and press the small ball/detent while pulling on ignition cylinder - ignition cylinder will come out. (do NOT remove the key!!) Look closely at the removed cylinder and find the small brass contact. You can wrap a bit of tape around it or simply pull it off.
Reinsert ignition cylinder; it will click into place. Alternate method is to cut the black with pink tracer wire that runs up to the ignition cylinder.
Phil
Old Jul 28, 2006 | 05:18 PM
hdrider876's Avatar
hdrider876
Smile
I realized after posting that it had been discussed in other areas. I got it taken care of based on your instructions. Thanks for your help.
Old Jul 28, 2006 | 05:26 PM
FortyFords's Avatar
FortyFords
Another dinger bites the dust !
Rich
DirtyDieselPhil
Glad to help - this was the first mod i did, and for exactly the same reason -
glad it worked for ya.
Phil
Old Jul 28, 2006 | 05:30 PM
Autobahn F-250 Lariat's Avatar
glad it worked out for ya
Old Aug 25, 2006 | 12:35 PM
Lonewolftx's Avatar
Lonewolftx
'06 Update . . .
I have the '06 F250 SDlKR Fx4 and the wire is now attached to the top of the key cylinder bracket, part of the steering wheel housing.
The Blk/red tracker wire has its' own clip that attaches to the bracket where the cylinder slides in. Just dettach it and set it in the column hole there.
Works like a charm w/ no more Ding, doing, ding . . .
