Sponsored by: Real Truck
This doesn't look right - Auto vac hub
Old Sep 30, 2017 | 03:37 PM
andym's Avatar
andym
It's plug and play from what I understand.
Old Sep 30, 2017 | 03:58 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
It's a piece of cake to switch over - beware though, that with Warns, they use a spring-steel ring to hold the locking hub in the axle hub. These rings are not thick enough to hold the hub still and they will rattle when you hit bumps. Before installing them, email Warn, and they will send you another set of rings (within a few days) to add to the existing ones and that will keep them steady.
Old Sep 30, 2017 | 04:05 PM
Firefighter 1406's Avatar
Firefighter 1406
X2 for the WARN Hubs. Replace and never look back. I ran the WARN premiums on my 99. Look great and when you turn and here the "click" no questions. You are good to go.
Old Oct 3, 2017 | 02:01 PM
magnumak1's Avatar
magnumak1
This is the only guy I've seen that opened up the hubs completely and it requires having a hole in the selector like you already have. Not sure how you seal it back up again but it shows the remainder of the hub that guzzles service write up leaves alone.
Old Oct 3, 2017 | 02:29 PM
77F2's Avatar
77F2
Thanks for the info on the warn hubs and thanks for sharing that video.
It's nice to know how to disassemble if needed.
Old Oct 3, 2017 | 04:33 PM
krewat's Avatar
krewat
Weird, I had mine completely - and I do mean COMPLETELY apart without poking holes in that filter. YMMV
roguewave
34
Oct 20, 2019 06:00 PM
Fordking1978
Aug 30, 2017 03:01 PM
dpilot83
Sep 11, 2014 10:06 AM
79-400-POWER
Offroad & 4x4
Aug 16, 2007 03:25 PM
gyger1
Offroad & 4x4
Jun 27, 2007 12:10 AM
