Running rough, suspected vacuum issue.
A few years ago I bought a 1996 F150, with a 5 speed and straight 6. I had it for two years, then I sold it because I needed something bigger. When I sold it, I could not get it the emission systems to ready up for the inspection. The guy who bought it tracked that down to a cracked air tube, and he took it all apart to replace. Once he got it apart he found out he had a baby on the way, and realizing he didn't have time money (and realizing he isn't a great wrench turner) I wound up buying it back very cheap.
I got the air tube, and put it in. I also got everything else back on. Luckily this is a pretty simple engine, because putting something together that somebody else took apart can be a nightmare. Actually, the vacuum lines where a nightmare. I spent hours looking online trying to figure out the routing, then my buddy spotted the diagram on the hood
Before I had the lines figured out it would shake violently, then after following the diagram it still shakes some, but I don't know if it is a different issue.I got them hooked up to what I believe is the correct routing. However, I am still having issues. Before I list the symptoms, I will say that I am not 100% sure it is a vacuum problem, so keep and open mind!!
When you first try to start the truck, it fires right up. Once it is running, it runs well for about 30 seconds, then develops a miss, and the engine starts to shake. It will stay running for as long as you let it; however, if you shut it off by key, it will not start for several hours. Then when it does start again, it goes through the cycle I just listed. I have tried to test drive it, and it has almost no power.
Also, it has a new coil, new rotor, cap, plugs, plug wires, and some miscellaneous parts that don't really pertain to the problems, so I wont list them.
The truck did sit for about a year, could it be a simple case of clogged fuel lines? Maybe a stuck or gummed up injector? While it was sitting the tank was on empty, and I filled it up to half of a tank with fresh gas.
I am really trying to avoid dropping the tank, since the straps and bolts are not looking too healthy; however, I am willing to do it if you guys think that could be the issue. I am not sure where to take my next step, so any advice is appreciated!!
1 year old gas is very suspect but i would check spark and fuel pressure first, along with pulling codes, long before i would drop the tank.
clogged fuel lines or filter? maybe the pump?
I have tried that, it does not help.
Could the injectors be stuck? I know it is a common problem when diesels sit for a long period of time.
Before I did the pump swap I tested pressure again, and it was 0 across the board. I figured the gauge wasn't working, or I had it hooked up wrong, or the pump completely went bad. With the new pump, I tested it and got 0 again. I unhooked it, and hooked it back up, still 0. I brought it back and got a different tester, still 0. Maybe the FPR is bad and letting an pressure go back into the tank?
