Running rough, suspected vacuum issue.
Old Oct 20, 2017 | 05:36 PM
Ryan313's Avatar
Ryan313
Did I stump you guys???
Old Nov 5, 2017 | 08:50 AM
Ryan313's Avatar
Ryan313
I decided to try some seafoam, even though I think the quick fix cans of whatever are usually a gimmick. I put some in the oil, some in the gas, and some in the vacuum lines. After I did that, it was starting after running, and it seems to be running a bit better, but still not perfect. Maybe I have stuck valves when it gets warm or something? When it was sitting it was taken apart, and the valve cover was off with a garbage bag over the engine.
Old Nov 5, 2017 | 01:40 PM
rla2005's Avatar
rla2005
You need to get a handle on the true fuel pressure. The engine will not run with 0 PSI per your previous post of fuel pressure.
Old Dec 19, 2017 | 06:57 PM
Ryan313's Avatar
Ryan313
Does anybody have any ideas? I need to get this truck going
Old Dec 19, 2017 | 08:16 PM
rla2005's Avatar
rla2005
Old Jan 7, 2018 | 01:16 PM
Ryan313's Avatar
Ryan313
When it rains it pours, but I was finally able to get a chance to test it.
Key on engine off it is 20 psi, and starts. If I cycle the key I can get it up to 53 psi before starting. I can also start it if it is at 20 psi, and it goes right up to about 50 psi. Hitting the throttle it goes up to about 53 psi. I drove it down the road and it held pressure the entire time. When I got back I shut it off, no start. It still had 53 psi when I was cranking it and no start.
Rapidrob
Jun 16, 2017 10:49 PM
Snowseeker
Jun 2, 2013 04:45 PM
Feo
49
Apr 5, 2011 05:28 AM
agclement
Jul 28, 2010 02:38 PM
71Hanker
1978 - 1996 Big Bronco
Mar 30, 2009 01:26 PM
