35's flat tire question
Old Sep 27, 2017 | 12:56 PM
C_Smitty's Avatar
C_Smitty
If you put 35 inch tall tires on your truck and you got a flat tire, could you get away with using the stock spare tire just to get you to a tire shop? Just curious since I think the stock tires are close to being 33's...
Old Sep 27, 2017 | 01:05 PM
Adam R's Avatar
Adam R
I've plugged the last 5 or so flats I've received and was able to do it without taking the wheel off the vehicle. It would be even easier on a SD with all the clearance you have to work with.
$5 plug kit and a $15 compressor and you'd be in business.
Adam
Old Sep 27, 2017 | 01:57 PM
LiquidSteam's Avatar
LiquidSteam
Adam
^^That's what I would do. I have not carried a spare tire since 2004 and I don't on my SD. I also haven't had a flat since the 90's lol.
If I was going on a long trip I may throw the spare in the back but with these tires mounted under the truck they get destroyed with rust where I live. I don't think I could even remove the spare off my wife's Mercedes now... it looks rusted solid.
Old Sep 27, 2017 | 03:55 PM
Sleepyguy's Avatar
Sleepyguy
The jack on my 2008 f350 SD with the 6" lift and 35" tires worked fine just had to make sure they jack was on stable ground. If it sinks at all then your cutting it close.
I really dislike the jack though due to its small size and the trucks overall weight.
I don't see any reason why it would not work.
Old Sep 28, 2017 | 12:21 AM
wfedwar's Avatar
wfedwar
Yes. (10 char minimum)
Old Sep 28, 2017 | 08:04 AM
C_Smitty's Avatar
C_Smitty
Thanks guys....
Old Sep 28, 2017 | 08:15 AM
nuctrooper's Avatar
nuctrooper
Yes, but...
One important caveat — if you have a limited slip rear and get a flat on the rear, put the smaller spare on a front corner, and bring that full size tire to the back. If you have a locking rear, avoid using the locker with different size tires (though if you’re way off road and need a locker, anything goes). Also note, when the smaller spare is on the front, your braking will be affected, so be extra cautious if hauling a heavy load as hard braking will likely pull the truck to one side. Bottom line - go for it, just know the effect and repair ASAP.
Old Sep 29, 2017 | 12:46 AM
MadeInDade's Avatar
MadeInDade
If I put 35's on the truck and replaced the spare with a 35, would it fit under the bed where the normal spare is? Can that space fit a 35?
Old Sep 29, 2017 | 08:15 AM
kylant's Avatar
kylant
yes................
winterkill
Apr 6, 2019 04:59 AM
DieselMama
Nov 22, 2017 11:04 AM
03trueblue
Nov 3, 2006 08:57 AM
CrazySpyder69
1983 - 2012 Ranger & B-Series
17
Jul 10, 2006 05:57 PM
BroncoMTR
1978 - 1996 Big Bronco
Mar 21, 2003 03:57 PM
