Sponsored by: Kumho
Larger Spare Tire?
Old Nov 2, 2006 | 08:38 AM
03trueblue's Avatar
03trueblue
Larger Spare Tire?
I have recently replaced the stock 235-75/15 tires on my 1989 F-150 with 31-10.5/15 tires, and I still have the standard spare.
My question is, if I get a flat and put the stock spare on with the 31's is this going to hurt things until I can get the tire repaired?
Thanks.
Old Nov 3, 2006 | 01:58 AM
Torque1st's Avatar
Torque1st
Posting Legend
No worse than a donut spare.
Old Nov 3, 2006 | 06:46 AM
aurgathor's Avatar
aurgathor
If you use it on a non-driven wheel, or on an open differential, there will be no effect with respect to extra wear. With a LSD or locker; however, you want to replace it with the right size ASAP.
Old Nov 3, 2006 | 07:33 AM
Sycostang67's Avatar
Sycostang67
What he said, but if you are cheap and have an LSD/locker and blow a rear tire, you could move a good front tire to the back and put your spare on the front instead. I didn't want to spend an extra $200 on a full-size spare, so I will have to swap tires if I blow a rear one.
Old Nov 3, 2006 | 08:57 AM
03trueblue's Avatar
03trueblue
Thanks for the help!!
