Aerostar Ford Aerostar
4r55e vs a4ld
Old Sep 26, 2017 | 05:39 PM
davran's Avatar
davran
4r55e vs a4ld
All,
I'm looking at a '95 awd Aerostar camper conversion. I've read that the 4r55e is a better transmission than the a4ld, and that the changeover was '95.
How do I tell one from the other? I've looked up pictures on the interweb, and I don't see a difference in trans pans.
Thank you in advance,
Dave
Old Sep 26, 2017 | 05:45 PM
davran's Avatar
davran
I found this just after pressing send.
Ford Ranger Automatic Transmission Identification
Old Sep 26, 2017 | 08:47 PM
93nighthawk's Avatar
93nighthawk
A4LD has a vacuum line going into it near the cat (where the vac modulator is) 4r44e is all electronic. 96 AWD had the 4r44e, 97 AWD had the 5r55e.
Old Sep 27, 2017 | 11:12 AM
davran's Avatar
davran
Thank you.
Turns out this is a 4.0 with the 4r55e.
Old Sep 27, 2017 | 01:28 PM
96_4wdr's Avatar
96_4wdr
good, one less thing, the vacuum modulator, to fail.
200,000 miles + on my 96 4R55E without a single problem running Mobil 1 ATF. Best auto I've ever owned until the BMW 750 8 speed.
Change filter. Gentle Flush with new cheap ATF, Walmart, then switch to 20 quarts Mobil 1. Several old posts on process. Add an inline filter. Bypass the radiator tank cooler, they hole and leak coolant into tranny, and the front air cooler. Put in the largest fin/plate cooler that you can fit in front of the radiator.
Old Sep 27, 2017 | 01:31 PM
davran's Avatar
davran
Good to know.
Car Guy
Aerostar
Jan 19, 2019 07:38 AM
savagefan
Aerostar
Sep 11, 2009 12:46 PM
brookwood61
Aerostar
Aug 3, 2006 01:18 PM
1red
37
Aug 30, 2002 10:18 PM
