No On Position, Only Cranking Position
Old Sep 26, 2017 | 05:39 PM
medrano_125's Avatar
medrano_125
I just got done rebuilding this truck (85 F250 with a 7.3 dropped in). I spent two years removing and replacing the engine and doing a complete overhaul inside the interior and the engine bay. When i insert the key to start the truck, there is no normal on position on the ignition cylinder. The truck starts to crank over in the on position as well as the crank position and i cant figure it out. I compared everything in the column to my buddys truck and everything looks the same, so im thinking there must be a wire somewhere where it shouldnt be. Any ideas?
Old Sep 26, 2017 | 06:15 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Rod / switch in the steering colum fubar
Old Sep 26, 2017 | 10:26 PM
wtroger's Avatar
wtroger
My vote is the switch on the column
Old Sep 26, 2017 | 10:33 PM
hairyboxnoogle
not the tumbler mind you, the switch at the bottom
softshoes
1983 - 2012 Ranger & B-Series
19
Oct 2, 2021 09:13 PM
Bootlegger's Deluxe
31
Dec 14, 2015 10:34 PM
alexmaras
Jan 19, 2013 01:26 PM
wjob
Jan 6, 2010 12:46 PM
smoke1380
Nov 4, 2007 01:35 PM
