Ok new questions
Timing chain covers I need to use my old one so I can run the mechanical fuel pump. The new motor has dowels in a different spot can I just not use the dowels?
The old timing chain doesn’t seem to be installed correctly? See pic?
Last one new timing chain doesn’t have slot for eccentric did I order wrong one?
Or do I need a different eccentric that uses the dowel on the cam?
