Possible Injector Problems?
Old Sep 24, 2017 | 01:43 PM
RhinoRidener7's Avatar
RhinoRidener7
I have recently replaced my Injectors, and have had no problems what so ever. I recently took my camper up into the hills about a week or so back and there was a lot of pumps and wash board roads. Today I was checking my oil and I noticed that the drivers side front plug that goes to the valve cover gasket was unplugged and the retaining clip broken, so I plugged it back in and zip tied it in place as a quick fix. I started the truck and it is running very very ruff and is puffing some white/clear smoke almost like its cold and I can smell what may be burning oil and the check engine light is on. I then unplugged the front plug leading to the valve cover gasket restarted the truck and it sounds fine idling smooth and no check engine light, a buddy of mine has a scanner and should be out tomorrow to take a look at the code. I was just curious if anyone could tell what they believe the problem to be.
1995 7.3l Powerstroke
MODS:
Stage 1.5 Full force Injectors
Hydra Tuner-
1. High Idle
2. Stock
3. 65hp Daily
4. 80hp Daily
5. 25hp Tow
6. 40hp Tow
Diamond Eye 3inch down - 5inch straight
Wicked Wheel II
S&B Cold Air
Glowshift Gauges - Fuel, Boost, Pyro
Old Sep 24, 2017 | 02:03 PM
farmert's Avatar
farmert
It sounds to me like you have an issue with that front under valve cover wiring, or the plug going to it, and when plugged in, the IDM is shutting that bank down to protect itself. Although it should not be running smoothly with that plug undone.
Old Sep 24, 2017 | 02:05 PM
97-psd's Avatar
97-psd
Did you look at the plug? See any bent or burnt pins? How does it drive with it unplugged? If the connector is broken the truck may run smoother with it unplugged vs plugged in. If you have ever worked on a gas burner v8 think of it like this, if you unhook 2 plug wires it will still run pretty smooth, but if you swap 2 then it will run like crap. Kind of the same thing. It would rather run with 2 not firing rather than 2 firing at the wrong time.
Probably needs a new plug, UVCH, or both
Old Sep 24, 2017 | 02:08 PM
RhinoRidener7
I figured it was something along those lines but with with it being unplugged I would think there would be a check engine light or wouldn't be running smooth. But it runs like a champ no problem
Old Sep 24, 2017 | 02:10 PM
RhinoRidener7
Plug looks fine no burns or anything, and it runs like a champ unplugged but when its plugged in it runs really rough
Old Sep 25, 2017 | 09:43 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Are you saying the plug is actually fully unplugged? Or just kind of cocked so it looks to be partly unplugged?
There's absolutely no way totally unplugging an entire injector harness clip will make the truck run well --at all--.
Killing 2 cylinders is quite severe and noticeable.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Sep 26, 2017 | 09:57 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Could you post a video of the truck running with and without the plug installed?
disturbinglee
Sep 4, 2019 08:39 AM
Bubba Jones
24
May 21, 2016 08:11 PM
lonerangerinaz
1997 - 2003 F150
Apr 14, 2009 05:26 PM
dd18
Jun 21, 2008 08:33 AM
skibum0101
Oct 31, 2006 06:36 PM
