1978 - 1996 Big Bronco
Water Temperature Sending Unit?
Old Sep 24, 2017 | 12:55 PM
Robertsma2's Avatar
Robertsma2
Hello all
Ive got a 92 Bronco with a 302 thats been giving me some erradic temp readings according to the gauge...pretty much always on the hot side. Warms up and drives fine but the temp gauge has always read a little north of the middle of the range. Sometimes it'll jump to the "L" on the Normal range or even higher and just hang out there. I have a thermal gun that i ise to take a direct reading at the thermostat...its usually between 185 and 200...truck has a 195 thermostat.
Im thinking the sending unit is bad, but never dealt with one. Any thoughts?
Thanks!
Old Sep 24, 2017 | 05:47 PM
Conanski's Avatar
Conanski
It's possible the sending unit is bad or has a bad connection, could also be that ther eis air int he system or a head gasket is failing. The sender is a small single wire device about the size of a dime right beside the #5 injector in the lower intake, the wire pushes on over stud on the top of the sender. If you replace it go easy on the thread sealer as the sender must ground through the intake, also check the ground connection to the lower intake on the rear intake bolt back near the firewall.
mavman4
Nov 19, 2019 04:03 PM
jimlj
Electrical Systems/Wiring
Jul 28, 2007 08:37 PM
hoxiii
Mar 2, 2007 10:33 AM
jclark4cs
Mar 19, 2006 10:15 PM
415dave
Nov 17, 2003 05:11 AM
