E4OD Hard 1-2-3 shifts, Wont downshift into 1st. - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco
Old 09-10-2017, 08:08 PM
Iron Port Iron Port is offline
Iron Port is starting off with a positive reputation.
Question E4OD Hard 1-2-3 shifts, Wont downshift into 1st.
I have a 1993 Ford Bronco XLT With a 5.8 351 Windsor, And an E4OD of course. It always had a problem where if you were to take off in overdrive the transmission would shift hard from 1st 2nd to 3rd, 4th was fine. But then it would only downshift into 2nd, not 1st. With overdrive off, It does not have this issue but creates these god awful back destroying shifts. The transmission was rebuilt at 147,583 miles and after 6 years it now has 147,673 miles. Obviously, it was not driven much. Now there is a leak coming from the front of the transmission. I should also note the truck has an erratic idle from 1200 RPM to 1000 RPM, it will rev hang at 2200 RPM if you give it a quick punch. Any help, please?
Old 09-11-2017, 08:59 AM
Redark1 Redark1 is offline
Redark1 is starting off with a positive reputation.
any codes. the idle needs to be addressed. don't understand taking off in overdrive. i can see 2nd by manual selection. if its in overdrive when taking off then a mistake was made in the valve body when it was built.
Old 09-11-2017, 11:55 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
That trans is 100% computer controlled and the trans is doing EXACTLY what the computer is programmed to make it do when it detects a problem with one of more sensors in the powertrain. Not incidentally.. a TPS sensor issue will trigger this "safe mode" behavior from the PCM so I wouldn't be surprised if the engines idle troubles are related to if not the cause of your trans behavior.
Old 09-15-2017, 08:59 PM
Well,
Quote:
I have 313 and 411, Absolut no idea what this is trying to say other than," Your trucks ****ed up but I can't tell you why". Oh, and what I mean by taking off in overdrive is putting the shifter in D with overdrive on. Hope that helps a little
Old 09-17-2017, 12:09 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
have you done a fluid/filter change on the trans? make sure the trans fluid it topped off with the engine running?
Old 09-19-2017, 04:20 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Quote:
Originally Posted by Iron Port View Post
I have 313 and 411
Those KOER codes. Have you run the Key On Engine Off (KOEO) tests and Stored Code (aka CM) display?
Old 09-19-2017, 10:01 PM
Mark DeDo Mark DeDo is offline
Mark DeDo is new and has a neutral reputation at this point.
Your Neutral safety switch may be bad
Old 09-25-2017, 02:15 AM
Quote:
I will have them tommorow.
Old 09-25-2017, 02:19 AM
Quote:
Filters brand new from rebuild, I will replace anyway. Also the fluid is bright pink, but a little too high.
Transmmission Diagnosis Needed Benchwarmers6 2004 - 2008 F150 3 11-16-2017 01:49 AM
More trans issues 7threeaz Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 05-09-2017 03:34 PM
no 1st and 3rd? 460Powered350 1987 - 1996 F150 & Larger F-Series Trucks 14 05-05-2017 10:24 PM
92 f250 4x4 e4od Transmission swap to manual OldschoolBoy Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 12-10-2016 04:04 PM
AOD 4-2 Downshift LARIAT 85 1987 - 1996 F150 & Larger F-Series Trucks 5 09-07-2016 02:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
