Possible rubbing issues with stock wheels
Old Sep 24, 2017 | 10:51 AM
Torqd1's Avatar
Torqd1
Just got the 4in lift from Pro Comp with radius arms. Got new rims and tires as well. I got a decent trip coming up and wanted to put my stockers back on to keep the miles off of my mt's. The shop says they will not fit without spacers. Anybody know if this is true? If so that sucks. I can always swap them out and see, but it's kind of a pita without a lift. Thanks for any help.
Old Sep 25, 2017 | 09:38 AM
kylant's Avatar
kylant
why would they not fit??
i highly doubt a stock size tire would rub on a new radius arm. i cant imagine a new radius arm set-up being closer to the wheel and tire. in fact, most new radius arms provide MORE clearance than factory
only way to know is to test fit
Old Sep 25, 2017 | 10:55 AM
Tricon's Avatar
Tricon
Only thing I can think of is that the stock wheels are 40 offset and your aftermarkets are probably nearer to 0. Carli arms give you more clearance, not sure if the pro comp ones do. Actually, arent the procomps just a stock arm drop and not a whole new arm? That might be a valid worry then.
Old Sep 25, 2017 | 03:41 PM
kylant's Avatar
kylant
i don't see how a stock size tire can even come close to rubbing
Old Sep 25, 2017 | 04:11 PM
Tricon's Avatar
Tricon
I don't think anyone every mentioned stock tires... Just stock wheels.
mikeym1
Feb 14, 2018 09:29 AM
cjg1999
Aug 31, 2007 08:09 AM
MountainRider
1978 - 1996 Big Bronco
Dec 27, 2005 01:27 PM
93XLT150
Dec 31, 2004 11:25 AM
christaylor
15
Nov 30, 2003 11:23 PM
