C6 shift issue
Old Sep 23, 2017 | 10:02 PM
Grampa jepp's Avatar
Grampa jepp
C6 shift issue
I just got a 1979 f150 with a 460 c6 2wd. It's stuck in a forward gear. You can 'feel' the detects when you shift the lever, but stays in forward. The parking pawls in park work. Something come apart inside? Think it's an easy fix?
Old Sep 24, 2017 | 10:44 AM
5851a's Avatar
5851a
Ford Transmission Forum Try this if no one has an answer. Transmissions are Voodo to me.
Old Sep 24, 2017 | 11:17 AM
1996_5.8's Avatar
1996_5.8
Does it still go forward when you put it in park or reverse?
Old Sep 24, 2017 | 01:50 PM
Grampa jepp
Yes, still goes forward. Thats how i know its stuck in gear. Tries to move in park, but pawls stop it
Old Jan 2, 2018 | 10:52 AM
Grampa jepp
So i finally got back to this truck. It automatically shifts through 1st, 2nd, and 3rd just fine. But in neutral, reverse, and park, it's still in drive gear. Parking pawls hold truck, but still trying to go forward. External linkages were tight, and you can feel the detents. Pulled pan off, and everything seems to be hooked up and connected. I am now assuming something with valve body. Is there a 'test' for the valve body?
Old Jan 2, 2018 | 01:07 PM
fe390pc's Avatar
fe390pc
I think you still have a linkage issue. The truck is stuck in Drive. The shaft that actuates the shift change sounds like it is broken inside the tranny.
Old Jan 2, 2018 | 02:05 PM
Grampa jepp
The shift shaft operates the shaft inside the valve body, which it still does. Can move shift lever back and forth, and valve shaft inside body moves with it. That's why I'm thinking it must be the valve body, just that i don't know much about auto transmissions
Old Jan 2, 2018 | 08:27 PM
1976 f-250's Avatar
1976 f-250
Yer forward clutch pack has failed and is staying on creating the forward only situation. That trans will need tearing down. My guess is the clutches are welded together from overheating in the forward clutch drum/pack.
Old Jan 2, 2018 | 08:35 PM
Grampa jepp
Ok. That makes sense. Oil was nice and red, but there was a fair amount of black sludge on bottom of pan. P/O very well may have tried a oil change. At any rate, I found a decent used trans that I'm gonna throw in for now. I will get the original rebuilt, and have ready for when the real restoration starts.
Old Jan 2, 2018 | 09:34 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That's my guess, too. And I'm fairly certain we are right!
Old Jan 2, 2018 | 11:42 PM
Don Senkow's Avatar
Don Senkow
The fwd clutch seized will also cause a lockup condition in reverse as you will in effect have the fwd, low reverse, and reverse high clutches engaged. Going into reverse will feel like park as long as the engine is running.
Old Jan 3, 2018 | 02:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
91f250truck4.9l
Aug 30, 2017 05:13 AM
tanderson6817
Feb 14, 2013 05:53 AM
martin441
Dec 13, 2003 11:10 AM
airharley
Jun 15, 2003 07:44 PM
