Clutch Slave Cylinder Connector
Old 09-09-2003, 11:18 AM
NathanV's Avatar
NathanV
NathanV is offline
I have a 91 Ranger, 2.3L, M5OD transmission. I lost all the tranny fluid and blew the tranny. I was able to get another one that bolted right in but after it was installed I noticed that the connector for the clutch slave cylinder was slightly different.
On the 91 the connector was black but on the new slave cylinder the connector is gold colored and slightly different. Not much different, just enough so that they are not interchangeable.
Does anyone make an adapter that I can use? Do you know where I can get a new fitting to connect to the existing clutch hose? Any suggestions as to what to do?
I really don't feel like pulling the transmission again and swapping the slave cylinder if I don't have to.
Nathan
Old 09-09-2003, 08:30 PM
Hank85713's Avatar
Hank85713
Hank85713 is offline
if ya know what year the trans is maybe a wrecking yard or even pepboys, checkers etc. Thing is you need to change the line from the master all the way down not just a connector.
OEM from dealer if all else fails.
clombard42
15
06-23-2018 05:33 AM
Marteney
01-05-2014 01:33 PM
Pkupman82
12-09-2010 10:28 PM
gsthompson
05-08-2010 11:37 PM
Quick Reply: Clutch Slave Cylinder Connector
