Broke Down Kingman, AZ.
Old Sep 23, 2017 | 05:30 PM
Silver Dually's Avatar
Silver Dually
Hi Brothers,
Well today has not been a Good Day. We arrived at an RV park yesterday afternoon. Truck was running great. unhooked from the fifth wheel and shut it down. This morning went out to warm it up before we went into town for some groceries. It started right up but instantly ran very bad & threw a ses . Well got out the laptop & checked it out p1236 IDM problem. did a buzz test that came up with code p0236 cyl 6 low circuit. ohmed the pin on the UVHC it was 3.5. pulled the valve cover just to check the connections. everything was tight. 50 cent mod still in place no burnt or chaffed wires. the harness over the valve cover is not chaffed. So is there anyone around Kingman, AZ. that has a spare IDM? I am 2000 miles away from home and we are heading to Yuma, AZ. for the winter.
Thanks for your Help !
Old Sep 23, 2017 | 09:22 PM
F350-6's Avatar
F350-6
Ran very bad as in half the cylinders dropped out, or just like one of them dropped with a noticeable miss at idle?
Did you start the truck with the valve cover removed? How many on that bank were spitting oil?
Strictly diesel is in Phoenix. Not exactly close, but Dennis has a solid reputation and can get you whatever parts you end up needing.
If the entire bank is shut down, try clearing the codes and unplugging the injector. I've seen a bad injector solenoid shut down an entire bank.
Old Sep 23, 2017 | 10:15 PM
Silver Dually
Sounds like one injector dropped out. didnt start it with the vc off. I am in a rv park and not supposed to be working on vehicles here. I know about strictly diesel. Just trying to figure out what I might need. I cannot get any parts until Monday.
Thanks for the reply
Old Sep 24, 2017 | 01:42 AM
Kingkong0192's Avatar
Kingkong0192
At least you're in an RV park with your camper so it could be worse.
Im like 80% sure I have an IDM kicking around here. I will look tomorrow and if I do and you need one I can get it sent out Monday through USPS urgent priority mail.
Old Sep 24, 2017 | 06:59 AM
Silver Dually
yes, I could be on the side of the road. We were just at Lake Powell for 5 days. I 40 from Flagstaff to Kingman is not a place you want to be on the side of the road.
I am going to do some more checking today. I will ohm the wires at the IDM connector to the injector. I dd a lot of reading on the forum last night and it seems that an IDM rarely fails.
Old Sep 24, 2017 | 08:52 AM
bigb56's Avatar
bigb56
That's what I was thinking. There have been cases where guys inspected the harness but missed the bare spot. It can be very tiny and look like a spot of dirt. If there is a store nearby maybe you can grab a magnifying glass.
Old Sep 24, 2017 | 08:55 AM
helifixer's Avatar
helifixer
I have a spare IDM, I am in Chino Valley about 150 miles from you, you drove 30 miles from me when you were on I 40
Old Sep 24, 2017 | 09:09 AM
SaintITC's Avatar
SaintITC
My only experience with a failed IDM was it due to getting water in it through the vent plug. But that was on a '97 where the IDM was mounted right by the hood/fender line in the engine bay. Now it's buried under the DS fender well, so I think it's more protected there - and also much harder to reach.
The IDM provides power to each bank separately, but to all injectors on a bank together. It does have a protection mode where if one injector solenoid is bad it will shut down that bank. By bad I think it means shorted, as an open shouldn't affect the circuit, so as F350-6 mentioned, unplugging a bad solenoid should get the rest of the bank running. 406injectors has really good response and sells new solenoids (from Italy?) for $50. They're in Montana and also sell the bit for those screws.
I drove my '97 around one day hauling a ton of stone for my friends porch when I had one bank out. Yeah, it was slow, but it made it until I figured out the issue.
Old Sep 24, 2017 | 09:10 AM
Silver Dually
Thanks Helifixer,
pm me with your phone number, I will call you after I complete the further testing. rules at the park are no noise until 0800. not suppose to work on vehicles at all. so I have to be quiet about it.
Thanks !
Old Sep 24, 2017 | 09:27 AM
helifixer's Avatar
helifixer
number sent,
I will be at church from 10:00 until about 12:30
Old Sep 24, 2017 | 09:29 AM
helifixer's Avatar
helifixer
I have a couple low mileage reman injectors also
Old Sep 24, 2017 | 09:58 AM
Hussler's Avatar
Hussler
Are you sure on the P1236 code? Cant find it anywhere in my documentation. Internet search shows it's a fuel pump issue code.
Maybe P1263, High to low side short cyl. # 3?
Old Sep 24, 2017 | 10:39 AM
Silver Dually
my bad, sorry it was a p1316
Old Sep 24, 2017 | 01:05 PM
Silver Dually
update, I have the IDM out & in my hands. not an easy job without my real toolbox at home.
I ohmed the leads on the IDM connector,all check out good all the way to the injectors. I also completed the 3 step test to check the complete injector circuit. all good.
So, where I am at in the RV park I cannot switch injectors around to see if is a bad injector.
Any Thoughts?
Old Sep 24, 2017 | 01:25 PM
Walleye Hunter's Avatar
Walleye Hunter
Can you get the valve covers off and check for oil flow through the injectors? Can you try disconnecting one at a time and see if there's any difference?
