85 Bronco 300inline 6. Tranny fluid dipstick.
a manual tranny doesnt have a dipstick. you should have a fill hole and a drain hole on the trans. to check fluid level you would open that upper fill plug and you want one finger digit before you make contact with the gear oil. so depending on what manual tranny you have will determine amount of gear oil and type to use.
Thank you for that. Are you well versed with broncos ? Can I pick your brain ? Email me directly if I can. Jimiscrivner1984@gmail.com
mike-db
02-02-2011 09:32 AM
Monster350Ford
08-05-2004 08:54 PM
