Tranny fluid?
Old Feb 1, 2011 | 11:00 PM
mike-db's Avatar
mike-db
Tranny fluid?
So I need to check my tranny fluid, not sure how to go about doing that.
It's a three on the tree by the way, not sure if that affects it or not.
1981 F-150
Old Feb 2, 2011 | 09:32 AM
Franklin2's Avatar
Franklin2
Look for a plug on the side of the tranny, about midway up. Take the plug out. If fluid starts running out, you are good. If it doesn't, stick your pinky in the hole and see where the oil level is. If you can dip your finger in the oil, or a piece of wire, and the oil is right below the hole, you are ok. If you can't touch the oil, and it's way below the hole, add some oil with a squeeze bottle till it runs out the hole.
