tranny fluid
Old Apr 11, 2009 | 12:55 AM
octaneforce's Avatar
octaneforce
tranny fluid
this is going to sound like a newb question, but where do i add and remove tranny fluid in a 1992 f150 w/ the i6 and 5 spd. i cant find a dip stick or anything. i dont have alot of experience with manual trannys and i dont have a manual. -thanks for any help in advance!
Old Apr 11, 2009 | 02:26 AM
Opossum's Avatar
Opossum
Manual trannies don't have dipsticks, they have a plug on the side of the tranny about half way up. You remove the plug and full till fluid runs out. And there's a drain plug if you want ot drain it.
Old Apr 11, 2009 | 02:54 AM
Sycostang67's Avatar
Sycostang67
I saw a manual tranny with a dipstick once, I believe it was on a toyota or nissan truck. That blew me away
Old Apr 11, 2009 | 09:47 PM
octaneforce
what fluid would you recomend i use? i just remove the plug and fill the tranny to the top?
Old Apr 11, 2009 | 09:54 PM
Opossum's Avatar
Opossum
Whatever fluid is right for your tranny, I don't know what that is. And you will only be able to fill it to the bottom of the hole.
Old Apr 11, 2009 | 09:57 PM
jr32560's Avatar
jr32560
it does vary from year to year or who owned the vehicle! some are atf-some are gear oil=and sometimes the previous owner will just use 30 weight oil?
Old Apr 12, 2009 | 03:54 PM
Michiganford's Avatar
Michiganford
what i do to find what fluids my vehicles take is go to amsoil.com and look up your vehicle. then it will say what fluids are recommended for different areas of your rig.
