spark plug brands?
Old Sep 10, 2018 | 11:22 PM
TheMonson's Avatar
TheMonson
Once upon a time I had a malfunctioning Bosh platinum plug out of the box. This was years ago in an old car, mechanic was the one that found it because I was of the mind (at the time) that a brand new part couldn't be the culprit. I just run copper plugs these days and change 'em once in a while.
Old Sep 11, 2018 | 07:13 AM
Tedster9's Avatar
Tedster9
Some mechanics would ****can a plug and replace it, if it was accidentally dropped onto concrete. Cracks in the porcelain aren't always visible. While they aren't used too much anymore ignition scopes were once common to troubleshoot ignition system.
Old Sep 11, 2018 | 07:32 AM
Ozzie H.'s Avatar
Ozzie H.
All true. I'm still using my Champion cleaner/tester to do the plugs. It provides a "visual" of the plug's sparking ability under increasing air pressure from the compressor.
Old Sep 11, 2018 | 11:42 PM
Tedster9's Avatar
Tedster9
I want one of those but everyone wants stupid money for anything with Champion in the name. I don't want one that bad!
Old Sep 12, 2018 | 11:47 AM
HoustonDave's Avatar
HoustonDave
Used to have one at the dealership and it was amazing how many apparently clean nice plugs would start failing to fire at only about 90 pounds pressure.
True story - while stationed in Germany I did a complete tuneup on the '62 VW sunroof we had... ran like a rocket for about 10 miles and then started to sound like a 3 cylinder. Nursed it back to the auto shop on the kaserne and as soon as I pulled it in one of the older Germans who worked there came over and said "You used Champions, didn't you!" Yep, they had been out of Bosch. He says "Champions go bad in air cooled VWs... no one knows why, but they do." Took his word, got a ride to a German parts store and bought 4 Bosch plugs.. damn car ran like it was on nitro till I sold it. Haven't put a Champion in ANY VW in just under 40 years since then. Would love a good explanation.
Old Sep 12, 2018 | 12:01 PM
Tedster9's Avatar
Tedster9
It is strange, ain't it? I mean, it's not a high tech part, or doesn't seem like it anyway. I latched onto NGK when someone suggested trying one in my LawnBoy, Champion CJ-14 is the classic plug, danged if it doesn't seem to rev higher with NGK. No idea why it would matter. Supposedly plugs can start to misfire for no apparent reason. In modern engines this will cause a code to be thrown if it gets bad enough, though not of course in anything vintage.
Also if the plugs are ever flooded out this can permanently damage them, even after they dry out, and fouling is basically the same way. It's important to have the carburetor tuned right and avoid carbon and deposits and have clean burning plugs.
Old Sep 13, 2018 | 01:36 PM
Ozzie H.'s Avatar
Ozzie H.
It is amazing how little things mean something to an internal combustion engine. That's why some people do indexing or "clocking" of their spark plugs to position the side electrode a certain way in the combustion chamber. It will slightly affect the "flame front" and burning of the mixture.
https://www.summitracing.com/search/...dexing-washers
Old Sep 13, 2018 | 01:43 PM
78Hayride's Avatar
78Hayride
I just tried a set of Autolite Platinum in Hayride - 78 400 2v. Not so happy. Went back to Motorcraft coppers. Runs much better.
Old Sep 13, 2018 | 02:21 PM
SlikWillie's Avatar
SlikWillie
I've never had a problem with Motorcraft plugs or anything, for that matter. Unless you are running really hot spark, there is no need for expensive plugs.
Old Sep 13, 2018 | 04:08 PM
dogdays's Avatar
dogdays
It is a known fact that in drug trials, the placebo will be effective for roughly 30% of the test subjects. That's right, the mind is a powerful thing. That's why the butt dyno is virtually worthless. Spark plugs are like religious artifacts, there's a lot of "belief" involved. I've had less than half a dozen spark plugs bad out of the box. But it does happen.
Electricity as water? The analogy is made from time to time. Voltage works the same way as pressure. Amperage works the same way as flow rate.
A plug with multi electrodes doesn't divide the spark. The spark jumps to the ground that requires the least voltage for the arc to start.
R.
BaronVonAutomatc
Aug 26, 2015 12:57 PM
hodges710
Jul 3, 2012 06:55 PM
jfsully
Electrical Systems/Wiring
Feb 25, 2007 06:01 AM
96_4wdr
Aerostar
Jul 18, 2005 03:13 PM
DictatorDanny
General Automotive Discussion
20
Feb 9, 2005 10:20 PM
