Reverse camera
Old Sep 22, 2017 | 09:42 PM
Justforfreee's Avatar
Justforfreee
Reverse camera
Can anyone tell me if they would know why my 2013 Ford F-150 reverse camera works sometimes and other times I get a blue screen then turns off. Any help thanks
Old Sep 23, 2017 | 03:03 PM
paredneck33's Avatar
paredneck33
It sounds to me like there is a connection or ground issue. Start by tracing the wire to the connector to the rear underside of the truck bed. Pull the plug apart and check for dirt or corrosion. If that checks out, then continue to trace the wire to the ground connector and verify that it is clean and tight. Also check for breaks in the wire while tracing the harness.
kevgrn114
Jul 31, 2014 07:47 PM
SGTSIXER
1997 - 2003 F150
Sep 29, 2012 03:23 PM
kingkong1
Dec 12, 2010 07:15 AM
bohiaa
Dec 17, 2008 08:01 AM
pep100
2004 - 2008 F150
May 11, 2008 02:42 PM
