Clutch Slave Cylinder Coupling
Old Sep 9, 2003 | 09:56 AM
NathanV's Avatar
NathanV
Angry Clutch Slave Cylinder Coupling
I have a 91 Ranger with the 2.3L 4 cylinder and the M5OD transmission. The transmission died from not having enough fluid. I still don't know where it all went.
In any case I replaced the transmission with one from a 2000 F150 and installed it in the Ranger but then noticed that the slave cylinder used on the newer transmission has a slightly different fitting than my original slave cylinder. The late model connector is gold but my original slave cylinder connector was black.
How can I fix this without dropping the transmission again and swapping out the slave cylinder? Does anyone sell just the fittings that I can attach to the clutch hose? Does someone make an adapter I can buy?
Any suggestions?
gsthompson
1983 - 2012 Ranger & B-Series
May 8, 2010 11:37 PM
bugracer64
May 24, 2009 11:03 AM
Bullride_101
Feb 3, 2009 12:47 PM
NathanV
Sep 9, 2003 08:30 PM
WhyFord
Aug 3, 2002 07:10 PM
