'92 Ranger/'94 Explorer Transmission Swap
I have a '94 Explorer with manual transmission (Mazda). Recently the
transmission is broken and the rebuilt shop sold me one from a '92 Ranger (V6, 4.0L). I was told they are identical.
I installed it together with all new clutch parts. Both the new clutch master and slave cylinders are for '94 Explorer. After that, I found the clutch doesn't work (I don't feel any pressure on the clutch paddle even after completely get rid of the air in the system).
Now I just found that both the clutch master and slave cylinders are different for these two trucks. The slave cylinder for '92 is a little bit longer than '94. So I am wondering if my problem is caused by this.
I also don't know if the replacement of both master/slave cylinders to those of a '92 will solve the problem or they will fit at all?
Could somebody help me?
Thank you very much!
From WhyFord
From WhyFord
Marteney
01-05-2014 01:33 PM
Nightrain
1983 - 2012 Ranger & B-Series
07-01-2009 03:42 AM
