Yesterday I went over to Bullhead City, AZ/Laughlin, NV. At the bottom of "Davis Dam Hill" (Official SAE tow test site) there were about 5 or 6 new Super Duties hooked to various trailers sitting at the base of the hill, looked ready to do some pull testing. Just got me to thinking that just maybe some changes are in the wind. If there are no changes, I would think they wouldn't need to be testing anything. Does anyone KNOW anything yet???? Just curious.
Since the 2017 is a new model year for the Super Duty trucks I wouldn't expect many changes. It will be interesting to see what changes if any has been made.
I'd go with Tom on this one. 10 speed and power bump testing for the 2019 or 2020. As to the TBD, I think all early model year order guides have those placeholders but I guess anything is possible.
It's also possible a competitor had the Super Duty trucks for benchmark testing...
Well, there was at least one, a chassis cab w/ a bed on it that had "Ford Motor Company" on the door. So it would be doubtful that it was a competitor.
I wish I would have had the time to just stop and watch what they were doing!!
Reason: Add comment
Fair enough, that info wasn't initially provided.
So in this case, Ford is likely looking to boost tow ratings and or power ratings. RAM now has a factory 5th wheel with a 30k rating; Ford does not. RAM is also +5 on torque. Not meaningful in real life, but meaningful in marketing.
Likely the 2019 GM HD trucks will have more power and torque than 445/910.
I agree with transmission testing, however, it seems like any type of powertrain testing by Ford is usually done with masked prototypes. The only times Ford seems to avoid masking material is a day or so before the release of a new model year vehicle, like the RC/LB DRW '17 that was testing a few days before the '17s were announced.
Even with already-existing vehicles like the Ranger and Everest overseas, Ford still uses heavy camouflage on those vehicles, which are currently being used for powertrain testing in the desert.
I still believe powertrain testing is being done, but the lack of camo or masking has me confused.
Powertrain testing is done years ahead of actual release, and is quite often done on existing models. They just rip out the old powertrain and put the new one in. Eliminates the need for camo. Camo will show up closer to production as they test out the cooling of the new front end.
Yup on the masking!!! Generally. Last month there were some Dodges all masked up doing some testing also......but there was something that was a dead giveaway that they couldn't mask!!
