WTF!!!!!!!!!! driveline still causing a shake.
Took my drive line back out again today and had it balanced again, guy got it to 0, slapped back in truck and still have a shake at 30mph. I'm at my wits end with this and don't know where to begin to look for a solution. only thing that I have figured is the stock bolts and clips that hold center support bearing in place broke, so I went and picked up a couple bolts nuts and washers thinking as long as the bolts hold tight they should work. am I wrong?????
Need help....;.
Need help....;.
checked all angles and they are within spec. I was just looking at pics on google and those clips go between the carrier and the bracket it bolts to. clips are about 1/16" if you think about it 1/16 can equate to quite a bit as far as changing the geometry of the driveline. I called local dealership and they have 2 clips and 2 bolts for a grand total of 40$ OH DANG!
I guess that'll be my next step.
Did your vibration begin after installing any kind of vehicle lift or leveling hardware? If so, you can try the 1/8" shims under the carrier bearing mount. When I installed my 2-inch front leveling kit, I had to install 2 of the 1/8" shims to stop my drive line vibration. The carrier bearing and u-joints were all good at that point, and it was only the shims which were needed to tweak the drive shaft angle.
85F_150driver
06-12-2003 12:05 AM
