Yellow Sub has not Turn Signals!
Ok, sorry for the delay in progress, go busy at work. I am tinkering with the Yellow subs turn signals. They don't work. Fuse #27 under the dash is missing, after research, that might have something to do with it? Also I have some relays missing under the hood. DRL #1, DRL #2, and DRL #3? What are they for? Are they necessary? Going to try and get and inspection and tag this swimmer Friday. Then it will be driven daily working out gremlins as they appear. Been a PIA trip, but this truck is growing on me.
Ha, thanks, its gonna look better with my **** in the seat drivin it! LOL. Thanks for all the info! That will help me get it done. I appreciate all the help that you have given me through this journey.
lol,ok. got the blinkers blinking. missing 15amp fuse. fuse 27. I just hope it don't blow. I read where it can once it hits 5mph? now do it myself inspection, before the real inspection. No Horn! lol. fuse is good, cant find the horn relay in those diagram Yahiko. am I missing it?
I don't know where the relay is, but, I do not hear a click. I have searched for the relay location online. Tried in this time sensitive ford manual I have on CD, it wont open on my new laptop? Gave up on that. From what I have read about other ford models, it might be on the back side of the fuse box in the cab. C270H? I don't know? I haven looked to see yet? It very well could be the horns. They seem to be a PIA to get to, so I wanted to rule out the relay first.
Awesome, thanks Yakiko. But, where is the Horn relay located? I still can't figure that one out. Because there is no click sound to be heard.
That is correct.
But if your into taking things apart I have some photos of the way the CJB comes
apart. It's tricky but the relay could be replaced. There are some other discreet
electronic components in there also. Resistors and diodes along with the relay.
Remind me later today and I'll dig up the photos. I had talked to Ed about maybe
doing repair on the CJBs. But that was some time back. you need to first narrow
it down to it being the issue.
That is correct.
