Bed Panel Replacement
Old Sep 19, 2017 | 05:48 PM
4fords's Avatar
4fords
Question Bed Panel Replacement
I have a "extra" 80-86 long bed. Has anyone ever put 73-79 outer bed panels on a 80-86 bed? Looking at part numbers, the inner panels are the same all the way through 96. Is it as easy as removing the 80-86 sides and welding on the 73-79 panel?
Old Sep 19, 2017 | 11:06 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Correct that up to a 96 bottom and header panel are the same. So I have read on here anyway.
Panel removal help thread. https://www.ford-trucks.com/forums/1...made-easy.html
Old Sep 20, 2017 | 07:52 AM
1320stang's Avatar
1320stang
If I recall correctly, you have to use the '73-'79 rear stake pockets that the tailgate attaches to.
Old Sep 20, 2017 | 08:40 AM
ddepumpo's Avatar
ddepumpo
Interesting timing with this question. I recently purchased a 74 short bed ... 4 of the 8 bolts that attach the bed don't line up with the holes in the frame rails. The front and middle pairs of bolts are about 3/4 inch outboard (maybe inboard, can't remember) from the frame holes. After scratching my head for a while, I contacted the seller, and he said that the floor/deck was from a 1980 short bed. He didn't realize that they didn't line up until he was putting it back together. FWIW, he did a nice job putting the bed together, as I wouldn't have known until I realized the holes didn't line up.
That said, I don't know if long beds have this problem. In my case, since the bed is painted so nicely, I haven't decided whether to drill new holes. I also realize there is a support sleeve in the bed frame rail where the bolts are.
g84t8f1
Apr 30, 2009 09:23 AM
dgassett
May 17, 2008 02:45 PM
uliman
Sep 28, 2007 08:05 AM
1955effie
Sep 11, 2006 08:19 PM
olered53
Nov 19, 2005 09:22 AM
